I recently fitted a CM927 programmer into my house with a BDR91 relay box. I quickly noticed that the boiler seemed to be firing very often. I looked at the installer guide and, as I'm sure you're all aware, it's designed to fire up a certain number of cycles an hour so this is normal.
The default setting was to cycle 6 times an hour for a minimum of 1 minute, I've changed it to 3 times and hour now but I still have an issue.
Yesterday I stood in front of the programmer and the required temp was set to 18.5 and the room temp was 19 degrees and a demand for heat was still sent to the boiler! The relay clicks in for the minimum 1 minute and the boiler continues to fire until it reaches about 60 degrees and then it slowly shuts down.
I live in a new build and yesterday I tried a test and found it took 2 hours for the temperature to drop 2 degrees, even so my [noisey Potterton] boiler is still kicking in EVERY 20 minutes!
Can anyone explain to me what the idea is supposed to be here? I can appreciate that it keeps the house at the optimum temperature better than more but it seems like an awful waste of gas, especially when the default was set to every 10 minutes originally!
Thanks in advance
Thanks in advance
