Concrete floor + carpet tiles?
7 Dec 2007
Lincolnshire
OK here's the scene.
Modernish concrete floor with DPM underneath. Surface coated with what appears to be bituminous paint.
Previous owner glued hard lino-type tiles onto that. Next owner put poly liner (dunno what it's called, looks like tissue paper or spiders web!), and then laminate flooring on top.
When I took up laminate flooring, it was a swimming pool underneath. Water, worms, mould, the lot. Then smashed off the lino tiles to get back to the basic bitumen painted concrete surface.
Left it open for 12 months to see what happens, and it appears to be dry, so I assume that all that lot was causing interstitial condensation (?).
I now want to put simple carpet tiles down. However, there's (1) the possibility that the carpet tiles may provoke damp again (the floor is very cold, and I don't know if the carpet tile backing will breath), and (2) there's still the bitumastic (albeit now well covered in dust, so it's not as sticky as it was), which may not get on well chemically with the carpet tile backing. So some liner perhaps.
Thoughts appreciated.
