I am building a concrete block shed in the garden, and I am considering what to do regarding the roof.
The plans are to have a flat roof that is sloped to allow easy drainage. The problem I have is the building is an irregular shape but the biggest area is 6mx4m, and the beams supporting the roof would be running the 6m direction.
So the wooden beams would have to be quite hefty, so they wouldn't bend over that distance, what sort of size would anyone recommend?
What about using steel supports instead, sort of H shaped the other way round:
[code:1]
[/code:1]
Is this a viable cost alternative? presumably they wouldn't have to be that thick because the weight of the roof will be fairly minimal? Any thoughts/experience? any idea on cost of such an item?
Thanks in advance
[code:1]
[/code:1]
Thanks in advance
