it doesn't work like that. (how many volts is dangerous)
the following is in "leymans terms"
its the current that kills you
voltage is measured in volts.
voltage is the potential difference between two points.
Current is measured in amps (less than an amp is milliamps, as millimetres are to centrmeteres)
resistance is measured in ohms
resistance is "how hard to get from point a to point b"
The currrent that can kill you is said to be around 20 mA
to get 20mA to flow through an object (or you) it depends on the resistance of said object
if the object has a high resistance then more voltage will be required to drive the current through
equaly if the object has a low resistance it will need less voltage to drive drive the required current through
you can reduce the contact point resistance by making something wet, so if you having a bath your resistance is lower than when you are not in a bath (as in if you are dry or wet) equaly if you measure the resitance between say your dry hands it will be higher than when they are wet.
also if the resistance is high and the voltage is high the object carrying the current gets hot (thats how electric heaters work, you must have noticed the element glowing orange, that is the element getting hot as it has a high resistance)
similarly bad connections also have a high resistance, theses can also get hot causing fires
lets take a 10kw shower for example
it should have a 10mm cable now if you used a 1 mm cable the resistnace would be too high and the cable would heat up, melt and cause a fire (that is why we get worried on these forums, people do not realise the consequences of what can go wrong)
its actually how fuses work, too much current and the fuse wire melts breaking the circuit
You may also like to know that if the voltage is high enough it will actualy fry what ever it is passing through, so that is why you sometimes hear of people suffering from from burns when they get an electric shock.
Gruesome but true:
people who are sent to the electric chair are often fried due to their resistance rather than electrocuted.
Also the higher the voltage the more it can "jump" so that is why "overhead lines" are so high up, so they cant jump to you, which is why you should NEVER climb a pylon, because as you get near it the electricity will jump to you and.........say no more.
a typical pylon runs at 33,000 volts although some are higher and some lower . The household supply is only 230v and a battery is only 1.5 v, so you can see the major difference.
ac or dc (alternatiing or direct current)
In short alternating current keeps changing direct current does not
if you touch an alternating current it puts your muscles into spasam (tingles) and if you touch a wire it will "throw you"
if you touch a dc current it will "hold" your muscles and keep you there, so you may also die of suffocation since your muscles can not move (you can't breathe) that is why your house supply is ac not dc as although both will kill ac is slightly safer. not to mention it is easier to "transport" ac across the country as opposed to using dc. (another "useless" thread later maybe)
Please remember the above although true does not go into the exact details and principlas of what is involved, it is just a basic outline.
so remember if you are not sure ASK or better still get a qualified electrician, not some one who "knows a bit" as what they do is probaly dangerous.
Earthing and rcd's etc are also not mentioned as you didn't ask and it would have made this post even longer. but in very short terms
anything metal must be earthed for saftey sake unless it is double insulated
