Hi all
can you tell me is it ok to use undercoat on a radiator followed by gloss.
No dont use undercoat on rads/ hot surfaces, It will soften and crack. The reccomended system is to abrade lightly to key, wash, then one or two coats of gloss. The undercoat will also leave brushmarks,alarman said:Hi all
confidentincompetent said:No dont use undercoat on rads/ hot surfaces, It will soften and crack. The reccomended system is to abrade lightly to key, wash, then one or two coats of gloss. The undercoat will also leave brushmarks,alarman said:Hi all
I use normal dulux trade gloss etc dont bother with 'special' expensive non yellowing type paints.
If you got rust on rad, touch prime then gloss only.
alarman said:so would a satin wood be a better option if only one coat was going on
Yes if you think the rad is not dirty/discoloured. It is rare that gloss or satinwood covers in one coat, even if you use 'Solo' or 'Once'.alarman said:so would a satin wood be a better option if only one coat was going on
Magnolia Matt said:confidentincompetent said:alarman said:Well .... I have never known u/c to "crack" in a "hot" situation. Also .... I would never apply "one" coat of gloss to anything.
Hi magnolia. Sorry to strongly dissagree, BUt this was way I was brought up Note when gloss on gloss abrade and clean instructions. The rads I painted today were painted by me with one coat of gloss 9 yrs ago and no flaking etc. When you come across a rad that is flaking and cracking you can bet its the undercoat thats the problem.
Actually check at brewers if you like, they will tell you same I'm sure. I asked when dulux aquatec was new if undercoat was needed on rads they said no and so did dulux trade site.
alarman said:ok guys didn't mean to start an argument but thanks for the advice
Magnolia Matt said:confidentincompetent said:No dont use undercoat on rads/ hot surfaces, It will soften and crack. The reccomended system is to abrade lightly to key, wash, then one or two coats of gloss. The undercoat will also leave brushmarks,alarman said:Hi all
spice said:Magnolia Matt said:confidentincompetent said:No dont use undercoat on rads/ hot surfaces, It will soften and crack. The reccomended system is to abrade lightly to key, wash, then one or two coats of gloss. The undercoat will also leave brushmarks,alarman said:Hi all
I agree, I always undercoat a rad thats never been painted, followed by either gloss or satinwood, perhaps I have been lucky but all the rads that I have painted have never once cracked.
