Spot Lighting circuit
29 Dec 2003
London
Is it safe to run 6, 240V mains powered halogens, 50 Watts each, GU10 and 50Hz from a spur off a double socket. From the double socket is a 2.5 cable leading to a 5 Amp switched fuse followed by a 2.5 cable leading to the light switch and from that a run of 1.5 cabling that connects to each lamp.
This is what the electrician who did the wiring in my new kitchen has done.
I can't help but worry that this is not best practice and likely to be questioned when I come to sell the house.
Any thoughts would be gratefully appreciated.
Cheers
Brian
its fine, strange taht it wernt taken off oringinal lighting circuit, but prehaps you are close to your loading max....
