Combining PIR functionality with basic switching
  • Thread starter Thread starter 2scoops0406
  • Start date Start date
Status
Not open for further replies.
2
2scoops0406
I was wondering if any clever bod could help me with the following. I am having a new driveway laid that has drive over led lights embedded into it. I want to incorporate a 2 gang switch in the garage in order to control the illumination of the LED lights in the following way :-
One switch (lets call it Power) will control the overall power to the lights, the other (lets call it PIR) will be used to control whether or not the lights are PIR activated or not. I've added a table below that describes what the behaviour should be depending on the switch positions
|..........Switch...............|.........Result...............|
|....Power....|....PIR......|..................................|
|..OFF..........|...OFF......|..lights are off..............|
|..OFF..........|...ON.......|..lights are off..............|
|..ON...........|...OFF......|..lights permanently on.|
|..ON...........|...ON.......|..under PIR control......|
Anyone any suggestions how I can achieve this?
Many thanks Ed.
there is an easier way. you can get pir's that if you turn the mains off/on in quick sucession will then keep on the light that is connected to it.
that way if you leave the switch on, the pir will work as normal if you turn it of the lights won't work, and if you switch it off/on quick the lights will come on and stay on
Breezer write slower....maybe I'll get in before you..... :(
i actullly read the post a while before i posted, had to have "tea break"  8)
Thanks for the posts :D ,
I've got one of these PIR's but it is always difficult to get the thing to work properly usually entailing me turning the thing on and off like a madman only for the PIR to re-activate. In addition to this the PIR seems to react differently depending on whether or not is is dark outside.
So while a good and valid suggestion, can it be achieved using 2 switches :?:
yes, nut its still easier with a pir, you also can adjust the darkness sensativity, i have got several of these
only need to switch off/on once
Hi
Going to annoy everybody now:
Whenever I fit PIR controlled lighting, I always fit what I call an override switch which is a bog standard one way switch.
Common to live feed, L1 goes to PIR output terminal.
This way, when the switch is down, the lights are perm on and when the switch is up, they work through the passive.
If you need this switch outside, you can use eg MK masterseal etc...
______________________________
lynda, moderator
please note forum rule 20
Status
