Plaster over Artex and Vinyl silk emulsion ???
10 Sep 2006
Trying to remove artex - what a nightmare !
Is it OK to plaster over artex and or vinyl silk emulsion on the ceiling and does anyone know how successful this is - or unsuccessful ?
Will it make any difference if I pre-paint with unibond 1/1.
Thank's.
I stripped off all my Artex using a steamer it takes a while but is quiet successful & doesn’t damage the ceiling too much. I then did some local repairs, re-taped the cracked joints & skimmed over. I did have one room that was very bad so I just put some new boards over the old ones, tapped & re-skimmed it - I just couldn’t face ripping the whole lot down & you cant see the difference!
Re plastering over Artex I’ve seen this done a few times without any problems but I suppose it will depend on the paint covering! Knock all the rough edges or pips off the Artex with a trowel (depending on the pattern) give it a sealing coat of PVA & let it dry. Apply a 3:1 coat of PVA & skim coat straight onto this.
dead right Richard :wink: that`s how my boy does it and we`re gradually loosing our textured ceilings one by one..he lets the final coat of pva go a bit tacky then spreads with multi-finish.
Thanks Nige & Richard, appreciated, have I read this Nige, that your guy skims over the artex and if so are any of the ceilings emulsioned with vinyl silk ?
Thanks.
the pva goes over everything bar grease :shock: .......any probs. arise from pimples on artex being a bit too long ........so we knock them off first.........
So Nige F, how about employing a plastic float, or is that just ridiculous?
Uses a wooden one for rendering/screeding ..I`ll ask him when he next comes round to borrow something :wink: .appears to do 2 thin coats of multi-finish then trowels up wetting with a brush all done with a metal trowel ........nice worn in one from his Father in Law (who taught him) saved me the bother of teaching him plumbing :lol: Did say something about different ways of trowelling .......and knowing him as I do he probably has worked out the easiest way..........so additional work with placcy float may be unnecessary .......That`s ma boy :lol:
Thank's Nige, sound advice and really appreciated, re; the PVA also the tips with the muti - coat and floats, I'll get a job as a pro- plasterer at this rate.
Invaluable info'.
Don't want to alarm you, but how old is your textured ceiling? When I bought my house last year the surveyor pointed out that textured ceilings could contain asbestos and should be treated with care i.e no cutting, sanding drilling etc.
Yes recon' I ain't got long to go, it is a knocking bet mine has asbestos in it, I believe it is over 20 years old which is around the time it changed over, I had a hel* of a cough the following day to scraping a section, needless to say it is going to get plastered over now after Nige offered the advice I was seeking.
Thank's Whistler, I'll let you know if the cough returns :roll:
roccodelucca said:
...I had a hel* of a cough the following day...
that will be due to not wearing a dust mask around builders dust. Asbestosis can take 20 or 50 years to show and is a kind of cancer. It is fatal and incurable so no laughing matter.
Thank's for that John I am fully aware of the health issues, yes I know I am a silly pratt, I have worked around builders dust for many years and normally always wear my mask, I should have known better, don't worry tho' if I see 20 years I won't complain and if I see 50 years I may just get into the Guinness book of records :roll:
