Looks OK now. Did you do something?
You could have just posted a reference to the Table number!The second one, yes, I could have made it smaller, but the column heading text in the first one really is already as small as it ought to get.
What a surpriseBAS, without bothering to reply individually to your questions
Not really.can I say that many years ago, when I was a product designer (some might say "when I had a proper job!), I worked on designs that used flexible cables on sub-sea oil valve actuators, at an ambient temperature that never varied from (I think) 4 deg C, and a steel sampling device that (again from my rather decrepit memory) had to operate at 850deg C. Do you think those tables would have provided me with any useful information?
I don't know BAS. Why isn't it 36A? or 10A? What's your opinion? And why are you asking?In Table 4F3A, why isn't the rating for 1.5mm² BS EN 50525-2-11 (née BS 6500) cable 50A?
I thought you wanted me to tell you why I thought it wasn't?I know why it is.
I want you to tell me why you think it is.
Let me give you a clue.
What would happen to 1.5mm² flex if I put 50A through it?
If I may jump back in, to make a comment from the perspective I was previously representing (BAS's may be similar) ......The answer to your question depends on a lot of things which you haven't specified. Off the top of my head, here are some:
What conductor material?
For how long will this 50A flow?
What insulation material?
How many cores, and to what are they connected?
What's the environment?
Is the flex in contact with anything?
Any forced cooling?
It's copper, of course, which is what BS 6500/BS EN 50525-2-11 cables use, as you know full well. Stop pretending that there are genuine reasons why you cannot answer the question - it's not making you look good.What conductor material?
Indefinitely, as is the case with all currents quoted in rating tables in the Wiring Regulations, as you know full well.For how long will this 50A flow?
PVC, of course, which is what BS 6500/BS EN 50525-2-11 cables use, as you know full well.What insulation material?
How many cores
Unspecified. Is it relevant? If so, why?and to what are they connected?
Any in which BS 6500/BS EN 50525-2-11 cables may be used.What's the environment?
Unspecified. Is it relevant? If so, why?Is the flex in contact with anything?
Any forced cooling?
I'm not avoiding any questions, in fact I can't even remember what is the question you are accusing me of evading.
I never said it did, and I never said there wasn't.I'm simply pointing out that the world does not begin and end with BS 7671, and there are more cables around than are dealt with in BS 6500/BS EN 50525-2-11.
Which of the 9 types that are included in that standard?What would happen to 1.5mm² flexible cable to BS EN 50525-2-11 in an ambient temperature of 30° with no forced cooling if 50A was put through it?
Did I say that?you were wrong to say that the rated CCC of a cable is not directly related to how the insulation/sheath performs as the conductor temperature
