I thought I did.say what =you mean bas
You're right - it does sound a bit like sour grapes, and it was completely uncalled for - you should be ashamed.COS IT DOES SOUND ABIT LIKE SOUR GRAPES BUT THEN AGAIN MY FRIEND ON READING MOST OF YOUR POSTS YOU ARE A COMPLETE CHANCER
No I have nothing to do with the running of this site.I presume bas that you have something to do with the running of this site hence your reply.
Maybe you should ask yourself what the point is of you coming onto a DIY advice site when you don't agree with DIY advice being given.Maybe at the same time you could ask yourself why NAPIT ECA JIB etc dont have similar sites to inform un skilled people how to do potentially dangerous jobs
So which parts do you agree with, and which not?and just to put you straight it is not the entire site that i disagree with most of it is fine
Can you give any rational and intelligent explanation of that comment?and if every body had your opinions we would all be working in the circus as clowns
What if the DIY advice wanted is instructions on how to do some electrical installation work?DIY advice is fine instruction on electrical installation work is another matter
I do.use your head
So so I, and at no time have I suggested otherwise. But having an opinion is one thing - expressing it is another. There are some opinions which you would be banned in law from expressing for example.and I unlike you believe everyone is entitled to there own opinion
What are your intentions then? If they are to answer every request for advice with "don't do it, get a qualified electrician" then you'll find I'll not be the only one questioning your presence.and I have no intentions of making anyone do nothing
So would you burn all the relevant books in the world?but at the end of the day if you are going to stick your hand up and say hey I know how to do this that and the other at least have the balls to stand up and take responsibility for it so the person whos life you have affected has some one to blame IF it all goes **** up for them
If you can find fault with any of the advice I've given then I'd be happy to discuss it with you.and maybe list your qualifications to prove you are competent enough to be giving the advice in the first place
sidmus said:DIY advice is fine instruction on electrical installation work is another matter
An isolator before the henleys would be better.Since the total load over the 2 properties is under 100A why not terminate the service tails on a Henley and run a set of tails to the primary consumer unit and a SWA of suitable size to the 2nd CU.
You should also consider having 2 x on / off switches to isolate the supplies before the CU so that the CU's can have total isolation should further work be carried out post the main install.
