NAPIT membership includes third party inspection and testing as long as the member is fully qualified and has the relevant experience to carry out this service and is present at first & second fix. When completing the Electrical Installation Certificate, in the case of a 3-part certificate only the 'inspection and testing' portion should be completed, if using the NAPIT Electrical Certificate you should indicate in the 'limitations' section that the certificate does not cover design or construction. In each case the details of the installer should be included on the certificate.
Please note that this approach should not be used to notify work under Part P as this is not allowed.
maybe if there wasnt sites like these people would not attempt it ... people have done work in there homes forever even before the internet
You've failed to grasp the concept of who is signing what.many companies use designated testers that are not present on first fix or for that matter second fix of an installation and that includes house builders like wimpy
Then there's no point you being here.in my opinion all electrical work should be left to time served and qualified people.
I don't doubt that you are, and you can inspect and certify electrical work from the POV of compliance with the Wiring Regulations.i assure you i am in a position with napit to inspect third party installations.
Then there's no point you being here.I am not sure I agree with this site giving information to un trained people
Then there's no point you being here.I thought the whole idea was to stop non competent people doing electrical work not actually encourage it which is exactly what you are doing
Would there?there is no proof that this site has prevented jack s""t in fact there would be more evidence to suggest people are more likely to attempt the work because of sites like these and therefore LESS likely to call a competent person and MORE likely to attempt work themselves
Then there's no point you being here.The correct response would be do not attempt it unless you are competent and qualified to do so if you are not find some one who is I am sure every thing that happens here is done with the best intentions but unfortunatly we are judged on our actions not so good if our actions result in someones death just a thought
