possibly also for not being OFTEC registered as I believe that is necesary for working on oil-boilers, isn't it ?
There is no requirement for OFTEC registration to work on oil boilers.
But it helps if you are!!
As a certifying body, OFTEC will not necessarily teach you about fault finding. It teaches rules and regs, because it assumes you know what you are doing. In the same way, Gas Safe does not teach you, it only recognises your ability to pass ACS, which again is rules and regs.
What these bodies give to a consumer is a route back to complain if your service is shoddy.
current situation is this - due to us having an option with our bank for emergency cover where they pay up to a £1,000 of repairs we have recieved the call from Homeserve (one of the banks preferred suppliers) and someone is coming today between 1pm & 5pm so fingers crossed we'll have some sort of diagnosis!!
The guy we've been using now for nearly 30 years now is a one man band operator and up until now we thought all ok and reliable however now know otherwise.
Hopefully once this is fixed we will be sourcing a company to service etc going forward.
Thanks so much for the replies and comments posted so far they've been really helpful , i'll post up again when i know more just to keep you all in the loop.
Bye for now from a very cold & fed up female
He doesn't need to be registered to fix it...I've followed on from a couple engineers called out through bank policies as they couldn't fix the problem...Guy form Homeserve turned up at 1.10pm and said oh no the office told me it was a gas boiler and showed us a text message they'd sent him saying this so he said i'm not registered to work on oil boilers so it'll have to be referred back to the office icon_evil.gif
The office then rang and said thursday - not good enough we said so were now waiting for another call
If your burner doesn't do anything at all once you press the lockout, I guess the motor is kaput, as suggested...unless the system has an air pressure switch somewhere.
Anyway, hope you get it sorted real soon - we would appreciate a post back with the result!
John
