Perhaps because they are a retailer and not qualified electricians they have made some faults, be a good citizen and point them out with the correct wording that they should use and send it to the MD.
Thats quite informative actually
As most of us are aware to the average home owner the reference to "low voltage" normally means 12 volt lighting and this has been the case to most lighting references since the 12 volts systems become common as it is technically a system working at a "Lower Voltage" to a 240 volt system.
