Hi all, great forums, hope someone can help ....
I have a Range Powermax 155x that started giving explosive ignition, and occassionally would not light. The boiler had a 2 year service due so I asked the engineer I called out to service and fix it. I had a Corgi engineer round, who did a load of tests, spoke with Potterton etc, and at their guidance changed the electrodes and the burner & gaskett. This did not stop the problem, and the next advice was to change the gas valve. This was also changed and did not solve it (although it tends to lock out now far more frequently than giving explosive ignition).
I then had the HT lead replaced, and on the last set of tests the gas pressure seems to start very low (about a bar or so) and then slowly build up to correct pressure (5 bar I think).
I am at the end of my tether (and overdraft!) - I have asked the engineer to come back and replace the new gas valve as I don't believe the gas pressure should start off low and slowly build up?
Potterton are being way less than helpful and just offer to come out and fix it for £279 - but I have already spent £500 so far (
Could this be down to the PCB? I have just spent about 20 minutes trying the boiler and after about 5 lockouts when trying to ignite (and you can hear the fan, electrodes etc all trying to igniite) it finally lit.
Once it lights it stays lit until the water is up to temp, water pressure is all as it should be etc.
Appreciate anyone that can help!!!!!
Thanks.
Thanks.
