All he had to do was RTFM.but he don't seem to no how the electronic switching works and the simple fact you can't put a mains live into a slave
You may.Can you use a single 2 gang switch so the 2 circuits are in the same switch & back box
Only if you want to (there is something to be said for two 1-gang switches, one above the other, for a hall/landing setup.)or would you have to use two single gang switches in separate boxes?
Like the ideaPut the landing light on the downstairs circuit. The light will then still be on if the upstairs circuit trips.
I'm surprised by that. So a switch can have two seperate circuits in it. Considering some of the regs this seems strange.
It can be argued (as I think it was, somewhere in the depths of this thread) that, functionally, having it the other way around means that there is sttil some light downstairs (hall) if the downstairs lighting circuit fails, and still some light upstairs (landing) if the upstairs lighting ciorcuit fails. However, wiring-wise it will not usually be so convenient to do that.Can't be bothered to read all that lot, so I'll own up if I'm not sure exactly what you're trying to do. But I think it's best to have the landing light on the upstairs lighting circuit; and the hall light on the downstairs lighting circuit. Why have it any other way (unless for some reason wiring is significantly easier)?
As someone said, given how hyper-cautious some of the regs are, it is perhaps a little surprising that it's still allowed, at least in domestic installations. I have to say that still put warnings inside back boxes if they contain more than one circuit, although it would often be 'too late' by the time anyone saw it! 541.11.1 of current regs still requires an easily legible notice "at each position where there are live parts which are not capable of being isolated by a single device...". Whether that does, or is meant to, include things like the light switches we're talking about, I don't know.As said, no problem having a 2 gang or more switch plate with two circuits or more present. ... Used to put notices in the back boxes once explaining more than one fuse or circuit breaker needs to be isolated for maintenance. Don't do that any more!
No I didn't.You may.Can you use a single 2 gang switch so the 2 circuits are in the same switch & back box
Safe isolation procedures......As someone said, given how hyper-cautious some of the regs are, it is perhaps a little surprising that it's still allowed, at least in domestic installations. I have to say that still put warnings inside back boxes if they contain more than one circuit, although it would often be 'too late' by the time anyone saw it! 541.11.1 of current regs still requires an easily legible notice "at each position where there are live parts which are not capable of being isolated by a single device...". Whether that does, or is meant to, include things like the light switches we're talking about, I don't know.
Cryptic questions asked without all the information needed will get cryptic answers back.So that red must be for all 2 way switches as powers always comes from the opposite to one of the switches ??
