NO.Is there a way of telling the age of the wiring in a home?
I would date it by the style of the majority of accesories, especially if mk
really? You should get out moreI aint seen many 50s or 60s installations done in Twin and earth
and if all the accesories were only fitted maybe 70s or 80s
would it be likely a majority have all been replaced again
True (although I don't know how far back in history that goes) - but, even if it does, that merely tells one the age of the 'wire', not necessary the 'wiring' - after all, some people are, for one reason or another, still installing pre-harmonisation cable today. Whilst the age of the cable is one issue, the age of the wiring installation is (provided the cable is PVC!) probably more important.Some T and E actually has the date on the sheathing
Grey PVC-sheathed cable has been aroiund for around 50 years. Cables with 'harmonised colours' insulation of the cores (brown/blue, rather than earlier red/black) first became available in the UK around early 2004. Pre-metric (i.e.'Imperial') grey PVC-sheathed cable can be identified by the fact that the cores of all sizes are stranded (whereas 1.0, 1.5 and 2.5mm² metric T&E cable have solid cores).cable is gray pvc, I think year on twin and earth cables started in 2005 or so, i could be wrong.
