I have a Belling fan assisted electric cooker with a ceramic hob. I need to replace the cooker element. Getting hold of a replacement element is the easy bit, how difficult is it to fit it or do I need an electrician?
I am going to give it a go, nothing to loose as the oven doesn't work anyway. Will have a go at most things but not very confident with electrics.................. am I going to end up with a perm??? I take it all the electrical connections are through the back of the oven? Is there anything I need to look out for?
Not if you isolate the cooker from its supply before touching it, and use a meter to test that it really has been isolated before you touch any wiring.
Um, your own flawed memory, if it's like anyone else's. Use either a camera or a notebook to record how each part is connected and/or affixed before you remove it.
We recently had to change our oven element and were a bit daunted being hopeless at diy. I found a website on the internet after doing a brief search with blow by blow instructions (with pictures) of how to do the job. We removed the old element which a local supplier checked to make sure that it was dead before he sold us a replacement. £35.00 job done, and there was I thinking that I was going to get a new oven - or perhaps even a new kitchen!
Just make sure you turn off electricity before you start and have a second person to help. Dont drop a screw down the back of the oven just as you finish We did.
