Hi anyone tell me what regs apply to putting a two way board in abrick shed about 5 meters from the house
The Wiring Regs I guess you know about.
The Building Regs also apply - as Davy said this work is notifiable. You can read all about that here:
http://www.diynot.com/wiki/electrics:part_p
There's no legal recognition of qualified but unregistered sparks - if you aren't registered to self-certify Building Regulations compliance then you're treated as a DIYer. But if your council is one of the miscreants that tries to make non-registered people pay for their own I&T you might be able to sidestep that fight by getting them to accept your EIC. But you'll still need to notify them in advance...
can I use a catenary wire from the main board or does cable have to be burried
No difference there to what's required in a commercial environment - the regs are the same for domestic.
does it need an earth rod I have a spare way in the board
cheers
Ditto.
supply is 2 cables in one to fuse one to N with earth terminal TNC-S[?]
Sounds like it, if the main earth comes from the cutout not the sheath.
In which case if you think the metal roof is an extraneous-conductive-part you either need to bond it (bye-bye 4mm² SWA, hello 10...) or make the shed TT.
Run cable through utility cupboard in trunking and out into meter cupbard
Got room in that cupboard for an isolator, DP Henley and a switchfuse?
was thinking t and e to metal stop end box on outside wall then glanded swa [4mm not sure I like joining two cables for same supply though thats why I thought catenary]
If you are going to connect to the house CU, and you can't terminate the SWA there, then instead of joining like you suggest could you put the adaptable box adjoining the CU, gland the SWA there but leave the cores long enough to reach inside the CU?
to two way cu in shed with rcd main switch with new addional rcd box in house
What's the RCD in the house for?
the meter cupboard is closer but not sure I wwant conect tails to meter
What could go wrong?
You're right - pulling the fuse is not to be recommended, but depending on your experience, its condition and what PPE you have access to it might be a decision you make.
and put rcd/main swich in there or whether I can
You're not supposed to, but as long as you don't damage, obstruct, or otherwise compromise the DNO's kit I doubt they'd come after you for it.
DISCLAIMER -
IANAL or a DNO employee.
Your experience may vary.
The value of my advice can go down as well as up.
This forum may contain nuts.
Don't eat yellow snow.
