Can anyone help, just replaced the honeywell 3 port valve, the wires are slightly different 5 wires on the old valve Green/Yellow, Blue, Orange, brown, grey. But on the replacement valve they are Green/yellow, Blue, Orange, White, Grey.
So I matched and connected the wires that would match and was left with a white to connect to a brown.
On switching the boiler on, it seems to work fine with the hot water, but when I switch on the heating, It seems like the valve opens but the pump doesnt start, so no hot radiators. There is also a contious clicking from the motor on the valve ( as if its switching on and off)
Could it be that I have the wiring wrong or could there be some other problem maybe on the control box pcb
The only reason I replaced the 3 port valve was because i was getting hot radiators when I run the hot water.
