H
holmslaw
I'm surprised that you think that different wiring regulations apply, or apply in different ways, to DIYers.I think the correct answer lies in whether you are a DIYer or a professional electrician.
All I've done is ask questions.I have yet to speak to an electrician who is a member of any organisation that would agree with BAS (a DIYer).
A fact is a fact regardless of how many people believe it or choose to not believe. For an example, please research heliocentrism and the remarkable Galileo.So it's a fact, but you only think you know why it's a fact?I'm afraid, whether anyone likes it or not, it's a fact. I think it's because of 131.8.
I'm not asking anybody to nit-pick, just asking questions about what people believe to be the extent of their "responsibility" etc.It is very easy to nit pick at the Regs and segue into clever arguments. Clever, but pointless if the sole reason is just to harp on.
What of the examples I listed?Now, I don't believe in slavish adherence to the strict letter of the Regs. As such, I believe there might be situations when 131.8 might be overlooked.
Example:
I'm not aware that any 'circuit' is rewireable or not in the terms you've expressed.Would you refuse to make a rewirable circuit safer if you were not allowed to add RCD protection?
A spur on what exactly? Add RCD where and to what exactly?Would you refuse to add a spur if you were not allowed to add RCD protection?
What have sockets and switch fronts go to do with this post?If you were asked to replace switches or socket fronts would you refuse if you were not allowed to add RCD protection?
Are you looking for support because this is what you do, in your own house as a DIYer?Would other people here?
You persistently rant about BS7671 not being the law, yet here you're making the explicit point that it is.A DIYer is still legally obliged to make reasonable provision for safety etc, which in practice means adhering to BS 7671.Of course, a DIYer can do anything he or she wants to do. Afterall, who would know?
It would be helpful if you could stop introducing imagined DIY thinking and concentrate on explaining, rationally, when, where and why the case exists for saying that existing components which you are not touching have to be updated to the current regulations....But a professional electrician offering a professional level of service, such DIY thinking should never be a part of their function as a law-abiding, Regs-abiding, professional electrician.
It would also be helpful if you stopped assuming that I'm automatically going to disagree with you just because I'm asking questions.
Until yesterday I would have agreed with “sealeon” in that only way is with separate rcbo’s but reading this quarters “Wiring Matters” http://www2.theiet.org/Publish/Wire...8_autumn_wiring_matters__complete_adverts.pdf I am not longer sure. Page 24 shows section of new on site guide which seems to favour the 3 way split boards.
The 3 way split board does not comply with reg 314.
I note the IET disclaimer "the IET is not as a body responsible for the opinions expressed"
OK - so when I was asking what people thought was required in terms of complying with the regulations when replacing a CU, what did you mean by "I think the correct answer lies in whether you are a DIYer or a professional electrician"?I'm surprised you think I think different wiring reguations apply, as this is not what I said
I've asked questions, not made points - can you not answer them?I'm surprised you think your point in any way makes sense or is relevant.
Your exact words were "it's a fact. I think it's because of 131.8". Was it not reasonable to express my puzzlement that you stated it was a fact but didn't say with any certainty why you thought it was?A fact is a fact regardless of how many people believe it or choose to not believe. For an example, please research heliocentrism and the remarkable Galileo.
Can you show me where I've said something factually wrong? I'm asking questions - if we're not to follow the regulations slavishly then can it be wrong to ask questions?So the fact is, as regards this fact, you are factually wrong.
I've asked questions - can you not answer them?You do so much nit-picking, you leave no nits for others to pick
Sorry - I thought that when I used the term "rewirable circuit" when referring to this question: "What if you had a rewirable CU with a circuit was on a fuse that was too big, and the customer was OK with you putting the right rewirable in, but wouldn't pay for CU replacement or an outboard RCD - would you refuse to do the work?" then you would know what I meant.I'm not aware that any 'circuit' is rewireable or not in the terms you've expressed.Would you refuse to make a rewirable circuit safer if you were not allowed to add RCD protection?
What about adding a spur? You could ensure compliance of your bit of cable by using conduit or BS8436 etc - do you think you have to bring the existing circuit up to 17th requirements?
They're an example of work you might be asked to do on an existing installation, so what they have to do with it is trying to establish when & where you feel that you cannot do work without bringing the existing installation to 17th standards.What have sockets and switch fronts go to do with this post?
No - it's because I'm interested in what different people think about this.Are you looking for support because this is what you do, in your own house as a DIYer?Would other people here?
I think "rant" is a bit OTT, but be that as it may, I'm not making an explicit point that BS 7671 is the law, only that it is probably the way that most people would choose most of the time to comply with the law. So if a DIYer chooses it then surely he's obliged to follow it?You persistently rant about BS7671 not being the law, yet here you're making the explicit point that it is.
Of course there are differences but if there are non-imaginary differences in the requirements of the Building Regulations, or in any other regulations which apply, I'd be interested to know what they are.There is nothing imaginary in the minds of most people as to the differences imposed in law on professionals selling a service and a DIYer doing a bit of weekend pottering about the house.
Will you please provide evidence of lies and misdirection in my posts?The fact that you wish to persistently introduce lies and misdirection into your posts is indicative of your addiction to those traits.
Will you please provide evidence of lies and misdirection in my posts?It would also be helpful if you didn't use lies and misdirection to bully through your points of view.
I for one would be very surprised if all consumer unit manufacturers created a new dual RCD protected board on a whim!
A spur on what exactly? Add RCD where and to what exactly?Would you refuse to add a spur if you were not allowed to add RCD protection?What if you had a rewirable CU with a circuit was on a fuse that was too big, and the customer was OK with you putting the right rewirable in, but wouldn't pay for CU replacement or an outboard RCD - would you refuse to do the work?
However, if you wish to proceed on the basis that it is the law, then "I think the correct answer lies in whether you are a DIYer or a professional electrician" seems even stranger.
....unlike our huge financial institutions that never miss-sell products, services and pensions to the gullable....?
FR - simply repeating an accusation is not evidence of its veracity.I refer the gentleman to the reply I gave some moments ago...
There's nothing to stop you reporting these things to Trading Standards and the HSE.
Keep us posted.
Ditto. Read your own words. The search facility is quite useful.Please provide the evidence, or stop, once and for all, making false accusations.
And will you also tell me please whether I can expect any proper answers from you to the questions I've asked.
made this comment? I do agree with.Moderator 11
Moderator Comment Posted: Mon Sep 22, 2008 4:25 pm This message will expire on Wed Sep 24, 2008 4:25 pm Comment:
please feel free to have a new one without people abusing each other.
It seems we can't make our minds up. It is however refreshing to see thought going into answers not just that's what it says so there.FingRinal
PostPosted: Mon Sep 22, 2008 8:05 pm Post Subject:
Well, we might as well all throw the big red book, guidance notes, on site guide and Part P books in the bin.
I did not and I have not.So why did you set the precedent and continue it?
I cannot see a proper answer from you to any of the questions I have asked you, even after I'd replied to your requests for clarification.All answers I give are proper answers.
I wonder whymade this comment? I do agree with.Moderator 11
please feel free to have a new one without people abusing each other.It seems we can't make our minds up. It is however refreshing to see thought going into answers not just that's what it says so there.FingRinal
