edited for clarity.
When you open the valve manually, the boiler and pump are controlled by the HW side of the programmer, and the HW tank thermostat. It sounds like the tank thermostat has decided that the HW is hot enough, and has shut the boiler down. With the knob on the tank stat going round in circles there's no way of adjusting it.
It's fairly easy for a DIYer to replace as long as you either get an identical one, or work out where the wires go. There are three wires, one is 240V live in, then two live outs, one is 'call for heat' and the other is for 'satisfied' - that allows the heating to work when the hot water is already hot enough. Lord only knows which colours the installer has used for the wires!
After leavin the heating on only one radiator nearest the airing cupboard went warm, not hot just warm, no other radiators came on. It's like it came on for a small bit then went off??
