I've lurked for a few months and now I've a question.
I have a Crosswater thermostatic mixer valve with two independent outlets. I have a pumped water supply that produces excellent pressure to hot/cold taps in the same room as the shower.
Recently (in the colder weather), the shower has only produced (at best) tepid water. If I leave the cold tap running and turn the valve up to max temperature, the temperature of the shower is able to reach a nice hot flow. If I stop the cold tap, the flow then returns to (at best) tepid. It's not going to be enough for winter.
I've taken the decorative parts of the mixer apart (ie, the front bit of the temperature dial, to expose the brassy bit of the valve) and turned the valve to its absolute maximum. I'm now stuck for what to look at next. Is there any possibility that the valve is simply not reducing the flow of the cold water enough? Is there something mechanical a bit further back that would only be revealed if I took off the whole face plate (which feels like it's been sealed in place by the fitter)?
I know Crosswater has a 15 year warranty - thing is, the fitter who did the bathroom didn't finish the job properly (problem with a cupboard/worksurface) 12 months ago. What can I do first off in this instance?
annaX
annaX
