Hi
I am wanting to add a single plug socket about half to two thirds way up a stud partition wall. Reason for this is I am wanting to mount my small LCD tv on this wall and don't want cables trailing down from the tv to the existing socket on that wall (directly below where I want the new socket). Existing socket is part of the ring main and is not feeding another spur. Basically, I am just wanting to sound out my plan of action to see if it's correct.
1. Cut a hole for the dry lining back box.
2. Remove the existing metal back box and knock out another entry hole for the new cable. Whilst removed it may also help in getting the cable down the stud wall.
3. Feed 2.5mm twin and earth from the new back box down the stud wall (hopefully there will be no noggins, wall width is only 1.5 metres). And pull out where the existing metal back box was.
4. Feed cable through new knockout hole and re-fit back box and make connections at both ends.
Does this sound ok?
I was hoping to take a feed from somewhere in the loft, but they only seems to be lighting circuits up there.
Does this sound ok?
