To give a little background on my worcester 24cdi...
i've recently decorated my spare room and had removed the radiator for access to wall ( closed both valves and drained pressure from radiator via bleed valve - system pressure not affected). Replaced and bled rad via bleed valve and checked system pressure and was around 1 bar (i think it was at that pressure prior to me removing rad) - increased pressure to just over 1.5 bar.
Everything has be ok for 2 days and now when i turn the heating or hot tap on the system fires up then pressure increases to 3.5 bar when the pressure relief valve kicks in - also there is a few banging/bubbling noises but i'm not sure if thats the relief valve operating??
Is it possible i've disturbed the sludge in system and has now blocked system?
