Hi all, I hope someone can point me in the right direction here...I'm not an electrition or gas man & i have no intention of messing around with this myself. I just wan't an idea of what the problem could be before I call someone out.
We have a inset Gas fire in the lounge which worked fine a while ago, however now it has a problem.
There is a switch (isolator i suppose) on the wall next to the fire. THis switches on ok...so far so good. Then you pull forward a brass plate on the front bottom of the fire & there is a small rocker switch which you have to turn on before you can light the pilot. This is where the problem starts. As soon as you flick the switch, it trips the circuit breakers in the house & all electrics go off!!!
Any ideas anyone?
THank you in advance for your help.
]Regards
R2oo
Any ideas anyone?
]Regards
R2oo
