Hello,
I'm studying Engineering in my final year at Bournemouth University. I am re-designing the door lifter. I am hoping to design a door lifter that supports the door when lifted and holds it at the required height without you having to apply constant pressure to the lifter. The idea is to allow the user the use of both his hands and to carry out fixing and marking the hinges without a second person. The product will be aimed at light to very heavy doors and to be used by apprentices, DIYers and skilled carpenters fitting heavy doors.
I was hoping to gain any points or needs that you feel would benefit you whilst using the product, even if they are very simple and obvious i would really appreciate your feedback. For Example: Lifting the door at set increments, or allowing the door to be moved in and out of the frame whilst on the lifter.
Thank you very much for any information you can give,
Jack
Jack
