Hello,
The zoning on my heating system has been fixed, but I am slightly worried.
When running the attic zone which only has one radiator, the boiler fires and the flow temperature quickly rises (Sometimes above the set flow temperature by a few degrees) it last around 1 minute and then cuts out, the boiler goes into anti cycling for a while then comes back on and does the same thing until the temperature has been reached. This won't happen when both zones are calling for heat (Other zone has 10 radiators and a Myson kickspace), it doesn't happen when only supplying downstairs either.
Is it because the attic only has one radiator?
Regards
Regards
