Can anyone help?
I recently had a new 3-port Diverter Valve AND a new Cylinder Stat fitted to my central heating system because a problem had arisen whereby my CH was coming on okay when timed to do so but my HW was not.
Both are programmed to come on at 6am (I have a Drayton LP112 programmer and both CH and HW led indicators were illuminated).
Only when the CH ended its first cycle at 7.30am did the HW (which is programmed to be on just "once") then activate and heat up properly. It then appeared to "fall asleep" again and not heat the water up when required to do so until the CH programme came back on again at 5pm, and it then activated again properly.
Another factor was that the HW was heating up to VERY hot, way above the 60 degrees temperature set on the cylinder stat.
In spite of renewing the 3-port valve and the cylinder stat this problem seems to be persisting. The boiler ( a Worcester Ri) is working fine.
It does appear to be an electrical fault.
I now find myself having to go to the programmer and either switch ON or switch OFF the CH in order to get the HW circuit to "activate" and come on.
Is it possible that the programmer is at fault here?
If so I will get it changed.
One more question - is it possible that the programmer is somehow causing the HW to "ignore" the temperature setting on the Cylinder Stat and allow the HW to get so hot?
Sorry for the length of this query, but I thought the more explicit I made it the clearer it would be.
