Baxi 105e Instant heating rads whilst CH is switched OFF?
23 Dec 2007
Bradford
My boiler is playing some sort of a game with me and i dont understand whats going on, or quite frankly hows its managing to do it.
But under normal circumsatnces the boiler does its job pretty well, heats the house when its timed to do so, and heats the water when the hot water tap is opened.
Now however, when the central heating is switched off on the timer, and i open a hot water tap for a couple of minutes the 2 radiators nearest to the boiler come back on. And they tend to stay on for a couple of hours after. Its usually just the 2 or 3 rads nearest to the boiler, the others dont heat up at all unless the central heating comes on. Its like having HALF central heating, when you dont want to.
So whats going on? I dont know much about boilers but from research im guessing something to do with the "Diverter Valve", maybe?
Will i need to get this valve replaced, or is there something else im doing wrong?
Thanks for your help.
Sounds like the DV is stuck mid position. Are you finding your HW is not as hot as it used to be as well?
Rads are getting hot when nothing is being used due to the pre-heat working on the boiler.
The hot water seems hot enough, but iv switched the pre-heat off, thinking this will help me solve the problem with the rads. But other than the fact that it now takes longer to get the hot water out of the tap, it hasnt done anything to stop the rads heating up.
Is there anything i can do to "unstick" the diverter valve?
