condensation in water tank
25 Nov 2008
Ipswich
I have condensation in my water tank in the loft, the water forms on the lid and then drips down the outside of the tank.
Many thanks in advance for any info.
kind regards
gg412310
Sounds like the lid doesn't fit very well.
Is this the cold storage cistern, or the F&E cistern?
If the latter, then some water vapour isn't unusual, but if the CSC then the water is too warm then there's a risk of Legionella growth, so you need to investigate further.
You are right the lid only fits when there is no water in the tank.
I believe it is a cold water storage system, water is distributed around the rest house from this tank.
Any drinking water is comes direct from the main before the tank.
You've completely mystified me with that comment.
In that case you have an exceedingly unhealthy situation - one that breaches the Water Regulations and defies common sense.
That's no crumb of comfort, because if you have a shower fed from the CSC then you risk any Legionella bacteria present in the cistern being sprayed onto your face and misted into the air ready for you to inhale.
When drained the lid fits the tank better than when full, there is about a 1cm overhang around the lid when full.
I believe the system is called an open vented system.
