Thanks Big burner, i'm making the asumption the pressure relife valve is required to be tested anualy ?
BigBurner (or Dr Drivel as we all fondly call him)
Mr Onetap you spouted lots of drivel on the other thread. Shocking.
is plugging his favoured, though eccentric, recommendation. He hasn't mentioned that the high temperatures that thermal stores operate at causes a lot of limescale in hard water areas; plumbers fondly call them 'sludge-buckets'.
Heat banks have removable plate heat exchangers - removing and descaling is a DIY job. What do plumbers know apart from drains. Look at some of them on here.
They're also pretty pointless with a condensing boiler; in fact they cause a huge loss of efficiency.
You haven't a clue about thermal storage. Ask gordonspants on the "Heat Banks" thread. You are so pathetic. Boilers with OpenTherm integral weather compensation connected directly onto heat banks/thermal stores are he most efficient you will get and no boiler cycling. The Broag has this. On the CH side have a Smart pump and TRVs all around - no wall stat. Two or more CH zones can be run off it too. Now you know.
Unvented cylinders sell because of ignorance by installers and also they get an annual service charge from one.
Look at this thread. Not one of these posters has the remotest idea of what they are on about. The distinct lack of knowledge regarding thermal systems and thermal layers is disturbing:
http://www.diynot.com/forums/viewtopic.php?t=15367
Look at this thread "Heat Banks" on how an integrated heat bank is put together. An amateur DIYer figured it out and bought one to order. He put to shame the so-called professionals on this forum, even doing so tests on how it performed, noting return temperatures that promoted extensive condensing efficiencies, which was impressive (Not to be disparaging, however it could be improved even further that is how efficient they can be, however a great result):
http://www.diynot.com/forums/viewtopic.php?t=137289
They can also be purchased off-the-shelf.
"DHW Only" Heat banks knock cobs off unvented cylinders.
Look at:
http://www.heatweb.com/products/cylinders/heatbank/pandora.html
An integrated heat bank (DHW & CH), as Gordonspants fitted, is different and cannot be directly compared to an unvented cylinder it is so much more advanced.
