How long?
26 Nov 2008
Berkshire
How long will a bell box ring if it has no battery back up in the main panel and the power is taken out?
It's the Glaxey 16 plus alarm panel (ADT).
Thanks to all in advance
try it and see.
by law its not supposed to operate for more than 20 mins, but if the timer has given up there is no saying how long it could go for
try it and see.
Thanks Breezer, on that thought will I guess it would stop after 20 minutes but will it then turn on again??
depends what you do as to what it does.
if the cables are cut or the supply is removed it is designed to stop after 20 mins.
how ever if the supply is reconnected and then removed it will agian operate for a further 20 mins
it should be 20 mins!
when i worked for A-nother D-am T-akeover (for my sins) i found that 99% of bells/sirens cut off after 20 mins :wink:
