Im just unsure about the RCD location as they are normally before the MCB in the consumer units. Ive never had to wire in a seperate RCD yet for a circuit.
can anyone install a shower circuit with new RCD from the fusebox fitting a new mcb? i thought this was where a normal person had to then employ an electrician or at minimum a registered competent person?
I'm sure I've told you at least once that anybody may do anything - there is never a case where you have to employ an electrician, not legally have to anyway, although lack of competence may mean that it's not possible for someone to do a satisfactory job, and therefore they've got no option but to employ one.
or if a normal person does it, is it that they are then required to notify it?
If a non-registered person does it, even if they are a highly qualified and experienced electrician, they have to notify it in advance. It's a controlled service - just like any other activity which requires Building Regulations approval you apply for approval before you start the work.
L&N from the CU into the RCD, L&N out to the shower switch...
I knew that bit
