I've got a Potterton Performa 28 with an external clock (on a wall in the kitchen), the make is Lifestyle ACL LS111. I've also got a Honeywell T6360 room thermostat. It's a small problem, but annoying, and no doubt bad for my gas bill!
My problem is that the room thermostat doesn't do anything at all. I can hear the click, but it doesn't make the heating go off. So when the clock is telling the heating to come on, it's always on. I tried changing the thermostat for a Drayton RTS8 (as I only have two wires sticking out the wall), but this also doesn't switch the heating.
So I looked at the wiring in the boiler. THere are L, N, Earth, 1 and 2 terminals. The manual suggests a room stat should be wired between 1 and 2. This is the case. There is also a connection from the clock to L, N and Earth. This all kind of makes sense. But there is also a short wire that connects L to 1. I don't understand why. And when I removed it the boiler was dead. So this seems to be supplying the permanent live. If I need this do you have any idea how I can actually have a working thermostat?
Thanks for your help!
