Just been up in the loft of our 14 yr old bryant 'executive' build house to change a cold water tank valve. whilst up there I moved some rockwool and found the loft light shorting out intermittently.
On closer inspection theres a leash of six cables bound together with yellow tape which are chock blocked into the back of the bathroom light below and one of the N wires was loose!
One wire is a 1.5mm three core and earth with the yellow cut back going to the extractor fan, another goes to the shower downlight, isolator switch, pull cord switch and the other two are feed and supply. Surely these should have been wired into a junction box in the loft rather than chock blocked within the bathroom light fitting?
Several of the terminal block ends are stuffed with 4 cables whereas I thought there was an unwritten rule that two was the max? No doubt this is why one of the wires worked loose. Phew am I glad that I discovered it!
Also the cables run OVER the joists and under the insulation! I thought that you had to pass the cabling through the joists as a minimum? I have checked under the rest of the rockwool throughout the loft and all the cabling is just draped over the joists! (thank F they didn't notch the joists as they are like matchsticks!)
Given that this was done in 1995 was it acceptable at that time or just a dangerous and bodged wire job by the contractors? Would I have any recourse with the original builders to pay for a proper sparky to come and redo the job?
