old honeywell boiler keep blowing fuse
29 Dec 2008
I've got an old honeywell boiler at home. It kept blowing the 3amp fuse until i turned down dial inside to off (presumably the water temp) when it is turned on it instantly blows. I've wired up plenty of new boilers etc, but i've never touched an old boiler like my own before. The power supply to it is pluged in like an appliance into a simple dial with off, 1-6, that is the extent of the electrics.
Are these still common to get hold of and for me to replace? or is it something else?
cheers
leccydirect";p="1102905 said:
cheers[/quot/)
i think its a loose wire in yea head or yea pump or yea fany or any thing with a coil try the missis with a multimeter i bet she got one bu...ggers to get out thou.
....nice one, big help.
I'll give a plumber a ring...who knows, it might even sort the problem out
he bgave you as much helpp as he could with the info you provided. are you not aware that the uk crystalball network is down right now. somnething to do with frozen crunchy credit or some cereal like that :?
