- Joined
- 22 Nov 2007
- Messages
- 100
- Reaction score
- 0
- Country
Hi all
I am asking questions like there is no tomorrow
sorry about that!
Lockshield valves. I have found a guide on the web that says to balance them you need to:
1. Open the lockshields and TRV's on all the rads.
2. Switch the heating system on.
3. Find the rad that heats first.
4. Check the temps on the pipes heating that rad, there should be a 12 deg temp difference, adjust the lockshield to make that so. (I used a digital laser/infrared thermometer)
5. Move on to the next rad and repeat the process.
So I did that, set the central heating thermostat to 30 deg (so the boiler wouldn't switch off during the process) and went about adjusting the rads.
Adjusted the first, moved on the the next then the next and so on. Went back to check the first and it seemed to be different to the 12deg I difference I set it to.
Is this normal? Should I expect this as I have adjusted others then come back to check from the beginning and should I re-adjust if it has changed? Not sure if I need to start the whole process again!
Thanks!
Thanks!
