- Joined
- 29 May 2007
- Messages
- 128
- Reaction score
- 0
- Country
Hello and I hope you can give me some advice
We had a new boiler and unvented water system installed last year.Our house is a 1920's built detached job with thick walls.
Since installation we have had problems controlling the temp-we use a Danfoss Wireless thermostat. The plumber changed the first one in case it was faulty but increasingly it seems to be the case that it is the reception
The only way the unit will respond is if we leave it in the kitchen (the boiler is next door in utility room) and that is hopeless as the kitchen is fairly warm so the boiler switches off when the kitchen temp is reached, leaving the rest of the house very cold. Ideally we would want the thermostat in the hall or living room
I am kind of wishing we had it hard wired but the cost and disruption now would be a real hassle
Are there "better" wireless thermostats around with stronger ranges or can Homeplugs be used to "boost" the signal or can you get a thermostat plus additional receivers??
Thanks for any and all help
Cheers
Cheers
