evening. new to breakdowns but seem tobe doing ok for some reason. i got called to ideal wf2000. fan running no ignition. checked aps that was fine. after potterting around i disconnected h/t lead on b oard reconnected and hay presto spark , pilot ,main burner!! fixed.
however im curious. before i attached the lead i tested for voltage to gas valve which was present. surely there should be no voltage to gas valve if spark ignition hasnt occured. what i learned about fault finding is where ever the voltages stop on the pcb that is your inbuild fault finder. as i said curious about that.ta
