I would like to fit a shower over my bath, the easiest way would be to replace the bath taps with a mixer tap that has a shower attachment but I'm not sure if that would work with my plumbing.
The hot water to the bath is from a HW tank fed from a cold water tank in the loft whereas the cold supply is mains pressure. Will I need to reduce the pressure of the cold water supply to the shower, or is a mixer tap simply not suitable?
Are these mixer tap showers any good, or should I just consider going for an electric shower.
