I am soon to modernise an S plan heating system. I plan to add thermostatic valves to most radiaters, excepting those in lounge that are controlled by the room stat. I assume i will also need to put in a auto bypass valve. Immediately after the pump is the T where the CH and HW pipes part, followed by the two valves. I plan to take the bypass pipe from here . The return pipe is out of convenient site below the floor, and the only bit showing is a 15mm bit from the outlet through the tank and also going into the floor. I have read that a bypass needs to be in 22 mm, but as the tank return is in only 15mm and this is where i can conveniently get too,it is in your opinions ok to have the bypass in 15mm also. It seems to me that if 15mm has been fitted on this pipe there is no point in having a larger one on the bypass. The boiler has no overrun and is an ideal balanced flue of some years, but reliable.
