I will shortly be refitting the kitchen and want to make provision for a condenser boiler to be installed at some time in the future. The boiler will not be installed in the kitchen but in the neighbouring room, replacing the 18 year old Ideal Elan 2 that is currently there. That room has no easy access to the waste system but the kitchen does, at least while it is being refitted. So I want to make a condensate drain available now so that the CORGI installer can make use of it some time down the line.
What form would such a drain take? Overflow pipe? Flexible plastic pipe? I will be fitting a standpipe nearby for a water softener that will be directly connected to the stack via a P-trap. What would be the best way to connect into it?
