hi i removed a radiator, closed the valves first, maybe im over cautious but the remaining radiators sound a bit noisier, i can hear the water running in, will that settle?
hi thanks for your advice, though i wasnt sure what one bar cold meant -did you mean with the heating off?
I turned the two taps a little til pressure went up, then put them back where they were originally is it that correct,
ps i dont normally mess with what i dont know
check the valves on the rad you removed ain't leaking![]()
Especially if one of them is a thermostatic valve!
