hi, wish i had left the rad on now! I bled the radiators, topped up pressure again, but it still drops after a while? The rad i removed, the valves are fine, no leaks,
jeanette
jeanette
jeanette
Yescan i use my gas fire meantime, if i have to turn off the heating?
hi i was wrong about the radiator valve the one on the right with the valve inside i turned off, hissed a bit when i checked it again, and it is leaking, seems a bit loose - do i tighten the bolt under it?
