Painting on fresh plaster.
6 May 2009
London
Hi all I would like the advice of you experienced decorators out there!
I am renovating my pals house into two flats and am quite short on time on the whole job. Building control have made me board external walls with thermal plasterboard which was something that there architech never picked up on . I have now boarded and skimmed them what i would like to know from you guys ( or girls :) ) is how soon can i paint them. I have bought dulux supermatt and usually when I paint over my skimming I wait a good week or more but like I said time is running short do I still need to let it fully dry or can you paint whilst it is still drying.
Obviously I want the job to be done only once and not cause a problem just wondered what experience you guys have had with supermatt.
Cheers
gaz
Supermatt is excellent paint..you can thin the first coat by up to 50% easy
As for the walls...the short answer is...when its dry., youll know that when they turn pale pink, normally after about 4 days
Cheers for the reply Zampa. I have never seen plaster dry so quick as on these thermal boards was pink after 30 hrs!!! I followed dulux guidlines of 30 percent as had not had a reply from my post..... Is that a bit thick in your opinion??
I wonder if you I can bother you with another problem that I have encountered ...... Artex ceiling that customer wanted flat so did the usual.... knocked nibs of unibonded then skimmed waited a week mist coated with cheap paint and not supermatt then hit with another coat ( fuller coat) but when I left customer to finish ceiling she called me back because it had blistered in a small spot so scraped back and filled was gonna go back and rub down and finish...... what did I do wrong? Ihave experienced this in the past( very occasionally) . I am not a decorator by trade but I do often finish my work off and have asked so many decorators and no one has really given me a definitive answer.
Cheers again bro!  8)
1 Yeh a little too thick I reckon..but it should be ok
2..Did all the paint blister?..as opposed to just the top coat?..if so it might be because the mist was too thick or the plaster was polished a bit too much
Hi Zampa ,
Cheers again for the responce, No not all the paint blistered just in a small spot (3" squared) don't reckon that mist coat was too thick but I am a hella for polishing my plaster! I have heard that decorators don't like the plaster polished so much but as a buillder I want to leave it smooth as I can what do you do if you come across polished plaster?
Nice one again Zampa. :)
I don't know any builders that like over pollished plaster, it's totally pointless & unnecessary! Paint will have one hell of a job sticking to it & all you’re doing is creating a decorators nightmare getting paint to stick to it in the first place but if anyone wallpaper’s over it in the future, the paint will most likely come off in lumps leaving a hell of a mess & a wall that, most likely, will have to be either completely stripped back or re-skimmed. :cry:
Shoot the plasterer & use a different one next time. :lol:
