Hi.
The top immersion heater on the unvented cylinder is leaking slightly. It's surrounded by limescale as we are in a very hard water area. it's a brand new fitted flat and apparently this problem has occured in other flats and refitting the heater has solved the problem as it has presumably been badly fitted at installation.
Can I just turn everything off and shut all the supply down, drain, remove and refit?
Thanks in anticipation.
