HELP PLEASE plate Heat Exchanger
26 May 2005
Essex
Help please,
I have a Ziilmet plate heat exchanger and would like to use it as a heatexchanger but not for a boiler.
Please can anyone advise how this unit can be plumbed as It only has female connections and for the life of me can not think other than a gasket how you can plumb 4 15mm pipes to it? :oops:
Do you have the answer?
It is piulled onto the pipes by the two bolts I am afraid. You'll have to make yourself a jig.
many thanks for that
I now can see that there are seal marks around the unit.
any Idea how much my pipes should enter the holes 5mm?
or what the other side on a boiler would be called?
Buy a set of plate heat exchanger power flushing adapters.
Plastic, complete with O rings and threaded connections.
