Personally I like a bit of a gap between outlets, I think its more aesthetically pleasing
And I'm glad you didn't do it vertically. That would have kept me awake at night.
Put some plastic covers on those quickly!
Look around here at example after example after example of electricians not understanding regulations, and always doing things the way they've always done them.I was pulled up on putting a TV point too close to a 13A socket outlet once, during an annual NIC inspection. The point being that if the face plates were changed to metal, then as the two plates could touch, this was not permitted. I'm not sure where this is indicated in the regs - I just took the advice of my inspector.
I suppose in this respect, even plastic back boxes would not be permitted.
Have I misunderstood something, or was my inspector wrong, or picky?
Not really - I like to see that too as you are probably aware in rural areas the odd power cut isn't rare.I would have thought it is good practice to wire two way switches so that when both switches are in the same position, the light is off.
Maybe I'm just picky![]()
Funnily enough I was taught that too as an apprentice and I still do it. Quite a few stripped/burred/broken ones behind me now too trying to get that last quarter turn.Once told to always dress them vertical so it it rained the water would run down the slot and not form a puddle.
I was 16 and sure he was taking the Michael!![]()
You can't have the correct torque *
Can't let you get away with this blatant 2A propaganda! But sorry about the crap photography.
BTW I don't dress screws. You can't have the correct torque *and* dress screws at the same time.
