gas pipework
  • Thread starter Thread starter ringy1
  • Start date Start date
Am thinking maybe this is someone having a little laugh and maybe I have fallen for it!!
I would personally switch off the warp core, prime the fussion matrix and then perform an anti matter purge through the aux matrix, your roast beef should be well done by this point, just don't over cook the veg or it will go all mushy!
then test the installation with a u gauge and do a let by test first im only messing
yea purge rig when the installation is done, but what i asked is before i solder in the tee how do i release the gas left in the pipework can any one else help please
To release gas left in pipework get a blowlamp, fire it up and point it into the pipe containing left over gas, this will ignite. blow up meter, half of house and yourself, if after this you can find your arms & hands, nose around in ashes to find piece of pipe, cut it, using a bit of wire wool & your teeth, clean both ends, flux & solder, perfect!
To release gas left in pipework get a blowlamp, fire it up and point it into the pipe containing left over gas, this will ignite. blow up meter, half of house and yourself, if after this you can find your arms & hands, nose around in ashes to find piece of pipe, cut it, using a bit of wire wool, clean both ends, flux & solder, perfect!
you forgot his eyebrows! and his hair :lol: :lol: :lol:
Dunno, never cut a gas pipe in a scenario, I cut one in a Bistro once.
Here is another scenario what would happen if i lit a match in a gas holder
you would probably burn him ( the gas holder ) quite badly and there is a chance that the gas that he is holding may itself also ignite probably causing fatal injuries, Probably.
