C
charliechaplinspants
This oversizing relates to the heat output, not the water content of the system,
What is that supposed to mean?
and in any case we don't know what the OP's original heating setup was,
Correct, we don`t neither does he but generally most combis can cope quite well with anextra couple of rads added, because they are generally oversized to give a better hot water performance.
it would appear from the problem and temporary solution that it was close to the limit for the expansion vessel fitted
I`m glad that the poster in your opinion is a plumber/heating fitter.
and the addition of four extra heat emitters, with associated pipework and additional water content, has taken it over the limit, hence the need for an additional vessel.
Bull.
I'm not familiar with Aristons, having never fitted them, but I do know that some boiler manufacturers will suggest or specify an additional vessel for systems over a certain size as the one integral to the boiler is insufficient.
Sounds like you are not familiar with any combis.
